Home > Maintenance & Modifications > L320 2010 Front Brake Carrier Bolts |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4968 |
Are you sure they are Torx headed and not just 21mm Bi-Hex? they are done up F/T as well 270/280Nm
Fri Oct 18 2024 2:07am |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 778 |
This may help if you want to work on your discs/pads. It's from the Disco3 site, but same as L320.
Fri Oct 18 2024 11:34am |
toeuk1 Member Since: 18 Sep 2011 Location: UK Posts: 29 |
Thanks for the replies. Yes, my mistake, I need a 12 point 21mm socket.
Fri Oct 18 2024 1:08pm |
