![]() | Home > Faults & Fixes > ACE HELP!! L320 Ace pipe yet another leak!! |
jig Member Since: 14 Jan 2018 Location: London Posts: 40 ![]() ![]() |
bump |
anyone?! |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5032 ![]() ![]() ![]() |
You can’t disconnect the joint in blue circle. Crimped on |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4440 ![]() ![]() ![]() |
You could always just fix it properly, and replace the pipework |
yes but im on a budget |
thanks |
Does anyone know if the pipe in blue circle is too corroded to take a compression fitting or if there is anyway to create a tight seal?thanks |
