Home > Faults & Fixes > ACE HELP!! L320 Ace pipe yet another leak!!
jig
2011 Range Rover Sport 3.0 TDV6 Autobiography Orkney Grey
Hi guys, need help and advice. I previously had one of the hydraulic pipes replaced with a flexi hose by a garage. I have now taken the wheel off and can see at the holder there is quite a bit of corrosion and the pipe is split and hence the leak. See pic (circle in red pipe 3). I have traced the pipe and plan to make some cuts and replace with hydraulic flexi pipes with flexi.
1. For the pipe marked in the blue circle it goes to the front (to the pump) and has a rust metal end and fits to a thick flexi pipe, can I disconnect this part or is it fixed to the pipe?
2. While I'm there I'm thinking of changing pipes 2,3,4.
3. the pipes are quite badly pitted, can if still get a good hold if I make the cuts before the bend?
Thanks in advance.
Jig
Post #644754 Tue Oct 15 2024 4:56pm
jig
bump
Post #644761 Tue Oct 15 2024 9:21pm
jig
anyone?!
Post #644766 Wed Oct 16 2024 5:36pm
You can’t disconnect the joint in blue circle. Crimped on
Post #644768 Wed Oct 16 2024 8:11pm
Disco_Mikey
You could always just fix it properly, and replace the pipework
Post #644769 Wed Oct 16 2024 8:57pm
jig
yes but im on a budget Sad the original pipes are quite expensive
Post #644771 Thu Oct 17 2024 10:09am
jig
thanks
Post #644772 Thu Oct 17 2024 10:09am
jig
Does anyone know if the pipe in blue circle is too corroded to take a compression fitting or if there is anyway to create a tight seal?thanks
Post #644794 Sat Oct 19 2024 4:02pm
