![]() | Home > General (L461) > P550e poor headlight performance? |
Workpermit Member Since: 24 Jun 2024 Location: Surrey Posts: 34 ![]() ![]() |
Sounds strange. Can't say I've noticed mine to be bad and I came from a 2022 SQ7 with laserlights. 2024 RRS L461 P460e AB |
JDPRRSUK Member Since: 13 Apr 2023 Location: Leeds Posts: 293 ![]() ![]() ![]() |
My lights are excellent - worth checking they are on and not just drl’s |
Zapp79 Member Since: 27 Jan 2016 Location: Staffordshire Posts: 37 ![]() ![]() |
No problem with mine - you can definitely tell they're on! Absolutely superb headlights and the auto dimming/blanking function is brilliant.
Lofc07182 Member Since: 06 Oct 2024 Location: London Posts: 6 ![]() ![]() |
Thanks for the replies. Yes I notice the animation and also checked to make sure the lights are actually on. Think I need to test it again when it’s completely dark. |
Done a bit more driving and i think the issue is that when lots of cars in front, it blocks out so much of the beam that I’m losing too much light. I’ve noticed when no cars it’s much better even on dipped beams.
scrumps Member Since: 01 Aug 2011 Location: Somerset Posts: 552 ![]() ![]() |
Hi,
Hi, yes checked everything. I’m pretty good with tech and settings etc. I have the adaptive on so it’s definitely blocking out parts depending on traffic. As I said I think it’s simply down to the fact that when there are lots of cars it ends up blocking out so much of the beam, that it makes it seem very dim compared to normal. I don’t seem to have any issues with brightness when I’m driving on quite roads with no traffic. |
