Home > General (L494) > Warranty direct claim 4 |
Turdmon Member Since: 05 Aug 2020 Location: Lancashire Posts: 118 |
What faults, out of interest? |
Fri Oct 04 2024 11:01pm |
Johnrrs Member Since: 16 Feb 2021 Location: Yorkshire Posts: 463 |
They work they did were, replace steering UJ the complete item, replace both front lower suspension arms, 4 wheel alignment, replace front anti roll (ARC) bar bushes. Total cost to WD £1720.55, total cost to me £150.00 |
Sat Oct 05 2024 6:23am |
timhum Member Since: 06 Mar 2017 Location: Suffolk Posts: 389 |
What was the cost of the warranty? Tim
Sat Oct 05 2024 6:58am |
So the UJ on the steering - did the gaiter split?
Sat Oct 05 2024 7:19am |
The warranty cost £1200. Not cheap…The U joint I think it was the boot that was split as they was going to try an aftermarket one but said if the tech wasn’t happy with it as it was new to the market then the whole joint would need to be replaced (don’t know why) but the warranty agreed to replace the whole joint so no problem. Not too sure with suspension arms, corrosion rings a bell. My car has done 49k miles. |
Sat Oct 05 2024 7:21pm |
Mine failed its MOT for the same split gaiter and was subsequently replaced under warranty. That's on a 2017 with 55k miles. That's a bloody joke IMO - its a slow moving part and should not be failing at all! |
Sun Oct 06 2024 11:27am |
