Home > General > RRS 2005 Supercharged Valve Body Replacement Advice
Markieboy123
United Kingdom 2005 Range Rover Sport Supercharged Stornoway Grey
Hi All,
Still have the issue with my gearbox thudding into gear usually between 1st and 2nd up and down and locking in 3rd gear with the F on the dashboard which clears with ignition on/off.
I have replaced the fluid and filter and had the gearbox reset however same issues remain.
The usual transmission errors P0781 1-2 shift and sometimes 3-4 show on the Gap Tool.
Car drives fine via manual gear selection which points to the valve body
Final piece of the puzzle is the Valve Body , to remove and replace with a good ZF6 HP26 unit or send mine for repair if possible?
Not sure if the VALVE BODY can be tested fully and confirmed before being put back into the gearbox?
Does anyone know if the valve bodies within all the ZF 6 speed boxes are interchangeable from discovery 3 to L320 sport to L322 ?
And if anyone has actually swapped one out ?
Post #643945 Wed Aug 28 2024 10:07am
I think a good specialist can test.
Some say the VIN code is stored in the megatonics unit and the result you are always stuck in 3rd. This is bolted to the valve body.
Others plug and play swap.
I would guess it’s important to swap petrol to petrol megatronics units. Or reuse yours.
I Do wonder if you are easing off the throttle when manual shifting? Or a full power shift?
Post #643947 Wed Aug 28 2024 11:06am
Markieboy123
Think the vin is stored in the mechatronic ECU which I plan to swap out, like you say it is sandwiched onto the valve body via a series of bolts.
I could re-program with the Gap IID tool but would rather swap out to replacement valve body if I have too
Be interested to hear if anyone has swapped out their valve body or sent off for testing
Post #643949 Wed Aug 28 2024 2:34pm
Lrstaylor
United Kingdom 2006 Range Rover Sport Supercharged Bali Blue
New I saw something about this before messing with the gearbox
?feature=shared
Post #643950 Wed Aug 28 2024 4:26pm
Markieboy123
I am seeing 13.73v with the engine running
Post #643952 Wed Aug 28 2024 5:51pm
Markieboy123
Just went out in the car with the GAP tool plugged in and the voltage showed 13.4v even at 3400rpm
Post #643954 Wed Aug 28 2024 6:50pm
Lrstaylor
https://www.rangerovers.net/threads/zf-6hp26-solenoid.233225/
Post #643957 Wed Aug 28 2024 10:27pm
