Home > General > RRS 2005 Supercharged Valve Body Replacement Advice |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5004 |
I think a good specialist can test.
Wed Aug 28 2024 11:06am |
Markieboy123 Member Since: 30 Apr 2019 Location: Hornchurch Essex Posts: 59 |
Think the vin is stored in the mechatronic ECU which I plan to swap out, like you say it is sandwiched onto the valve body via a series of bolts.
Wed Aug 28 2024 2:34pm |
Lrstaylor Member Since: 10 Mar 2022 Location: Kent Posts: 348 |
New I saw something about this before messing with the gearbox
Wed Aug 28 2024 4:26pm |
I am seeing 13.73v with the engine running |
Wed Aug 28 2024 5:51pm |
Just went out in the car with the GAP tool plugged in and the voltage showed 13.4v even at 3400rpm |
Wed Aug 28 2024 6:50pm |
https://www.rangerovers.net/threads/zf-6hp26-solenoid.233225/ |
Wed Aug 28 2024 10:27pm |
