Home > General > Engine oil leak
JJ WA
Australia 2012 Range Rover Sport 3.0 TDV6 S Sumatra Black
Engine oil leak
Hi I have an oil leak at the rear of the engine probably from the top dripping down. Any common issues?
Post #643825 Mon Aug 19 2024 8:14am
NoExpert
Inlet manifold gaskets and/or oil cooler. Take the engine cover off, look down the oil filter housing and look for signs of oil. If nothing there use a mirror to look at the back of the inlet manifolds for signs of leaks.
I’ve had both of these leaks and they definitely put oil down the back of the engine. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #643827 Mon Aug 19 2024 9:11am
JonnyCJ
I had a turbo return pipe gasket which was sorted (3.6 TDV8). Still getting drips and they turned out to be the torque converter seal and a gearbox seal. Was a gearbox out jobby.
Make sure whoever looks at it knows their onions.
All in, was around £1,300, but no more leaks and that included having some bronze bushes in the gearbox replaced and all fluids.
Post #643831 Mon Aug 19 2024 3:40pm
JJ WA
I took the throttle body off to have a better look at the oil filter housing. Slightly damp towards the back. Very hard to see beyond that due to all the pipes.
Post #643843 Tue Aug 20 2024 3:18am
JonnyCJ
What model is it ? might help in determining the issue.
Post #643845 Tue Aug 20 2024 8:15am
JJ WA
2012 Sport L320 3.0l Diesel Automatic
Post #643846 Tue Aug 20 2024 8:39am
