![]() | Home > General > Engine oil leak |
Inlet manifold gaskets and/or oil cooler. Take the engine cover off, look down the oil filter housing and look for signs of oil. If nothing there use a mirror to look at the back of the inlet manifolds for signs of leaks.
JonnyCJ Member Since: 25 Apr 2011 Location: Wirral Posts: 428 ![]() ![]() |
I had a turbo return pipe gasket which was sorted (3.6 TDV8). Still getting drips and they turned out to be the torque converter seal and a gearbox seal. Was a gearbox out jobby.
JJ WA Member Since: 19 Aug 2024 Location: Western Australia Posts: 3 ![]() ![]() ![]() |
I took the throttle body off to have a better look at the oil filter housing. Slightly damp towards the back. Very hard to see beyond that due to all the pipes. |
What model is it ? might help in determining the issue. |
2012 Sport L320 3.0l Diesel Automatic |
