Home > Maintenance & Modifications > U0428-86 Invalid data.... Vehicle lean caution.
Viagression
Ireland 2007 Range Rover Sport TDV8 HSE Rimini Red
Hi Team,
We just got a 2007 RRS TDV8.
It has come with the Vehicle lean when cornering caution.
Gap tool presents the U0428-86 code, invalid data received from steering column.
I have reset the SAS to 0, it was reading -6.8 degrees with steering wheel and wheels straight.
No difference.
Unsure if the ride and handling is incorrect as do not want to drive it too hard or far!
Noticed a slight wobble in steering at high speeds, but rims and tyres are pretty bad so I am putting that to the side for now.
I am going to check the plastic bush on the steering column this evening, but cant find a thread that definitely links my issues with that solution.
Appears to be hard fault which comes on right away when turning key.
All thoughts welcomed
Post #643402 Mon Jul 22 2024 1:36pm
Viagression
Plastic bush looks line, and is turning with the steering column
Post #643405 Mon Jul 22 2024 5:51pm
Viagression
Fault returns almost instantly after clearing it with gap tool.
Not sure what else could possibly be unless the sensor itself is having a wobble?
Weird that the live values are reading though.
Post #643406 Mon Jul 22 2024 5:52pm
