Home > Technical > 2012 RRS Correct 13 pin Towing Electrics
The Range Rover
United Kingdom 2012 Range Rover Sport 3.0 TDV6 HSE Lux Fuji White
HI
What is the best towing Electrics kit to fir to my RRS, as I want the correct "plug & Play" one for my vehicle.
Also is there any issues with this type of kit?
Thanks C
Post #643309 Tue Jul 16 2024 7:15pm
2012 might be around the change over time but no sure, if the harness connection Plug/Sockets are behind the the rear bumper the genuine L/R part will be VPLST0071 if they are behind the N/S/R light/ Boot panel it will be VPLST0015. I used the 13pin 0071 on a MY13 car. You could probably cross reference the o.e. part numbers to a aftermarket one.
Post #643316 Tue Jul 16 2024 10:18pm
philaldred
I recently fitted the 13 pin kit from PF Jones.
Nice easy fit, remove rear bumper and the factory plugs were sat there not too far away from the nearside rear light.
Instructions say to remove the spare but I did it with it in place.
Post #643413 Mon Jul 22 2024 10:43pm
You also have to update the CCF files to say it has a tow ball/bar etc. fitted to the vehicle, presumably I think mainly to do with rear parking sensors and rear fog lights.
Post #643425 Wed Jul 24 2024 6:31am
