![]() | Home > Technical > 2012 RRS Correct 13 pin Towing Electrics |
The Range Rover Member Since: 25 Jan 2010 Location: Whitburn Posts: 29 ![]() ![]() ![]() |
HI
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4934 ![]() ![]() ![]() |
2012 might be around the change over time but no sure, if the harness connection Plug/Sockets are behind the the rear bumper the genuine L/R part will be VPLST0071 if they are behind the N/S/R light/ Boot panel it will be VPLST0015. I used the 13pin 0071 on a MY13 car. You could probably cross reference the o.e. part numbers to a aftermarket one.
You also have to update the CCF files to say it has a tow ball/bar etc. fitted to the vehicle, presumably I think mainly to do with rear parking sensors and rear fog lights.
