Home > General > L494 4.4 TDV8 multiple Can bus issues |
JonnyCJ Member Since: 25 Apr 2011 Location: Wirral Posts: 323 |
As a test, run a jump lead to the battery from the earth wire point that's snapped off. You can then check whether it's the earth points or something else. If it is the earth points happy days - it's a simple fix.
Fri Jul 12 2024 5:08pm |
PC76 Member Since: 01 Oct 2017 Location: Northwest Posts: 398 |
Why on earth could I not think of that… and I’m not being sarcastic, been getting so frustrated with i..
Fri Jul 12 2024 6:32pm |
Sometimes you need a second set of eyes and a clear head !
Fri Jul 12 2024 7:08pm |
Ok, so RHS earth moved to sensor above and lost the ABS error. HVAC is not
Fri Jul 12 2024 8:12pm |
So using SDD the faulty modules are reporting a voltage of 11.8v. When I put in a parallel earth path that increased to 12v.. (bushman style in the dark so not entirely surprised of the miniature increase.
Fri Jul 12 2024 10:58pm |
Pic of SDD
Sat Jul 13 2024 12:34am |
Ok so update on progress made today.
Sat Jul 13 2024 5:17pm |
Hi all,
Sun Jul 14 2024 10:06pm |
