![]() | Home > General > L494 4.4 TDV8 multiple Can bus issues |
JonnyCJ Member Since: 25 Apr 2011 Location: Wirral Posts: 425 ![]() ![]() |
As a test, run a jump lead to the battery from the earth wire point that's snapped off. You can then check whether it's the earth points or something else. If it is the earth points happy days - it's a simple fix.
PC76 Member Since: 01 Oct 2017 Location: Northwest Posts: 402 ![]() ![]() |
Why on earth could I not think of that… and I’m not being sarcastic, been getting so frustrated with i..
Sometimes you need a second set of eyes and a clear head !
Ok, so RHS earth moved to sensor above and lost the ABS error. HVAC is not
So using SDD the faulty modules are reporting a voltage of 11.8v. When I put in a parallel earth path that increased to 12v.. (bushman style in the dark so not entirely surprised of the miniature increase.
Pic of SDD
Ok so update on progress made today.
Hi all,
