Home > General > Wheel fitting tool
JonnyCJ
Wheel fitting tool
Just bought one of these, which arrived 24hrs later. Not used it yet, but will no doubt be invaluable as removing and re-fitting Rangey wheels always fills me with dread
https://order.ebay.co.uk/ord/show?orderId=15-11763-66047#/
Post #643007 Wed Jul 03 2024 1:15pm
Puslinch
United Kingdom 2012 Range Rover Sport 3.0 TDV6 HSE Firenze Red
Great (simple) piece of kit. Saved my back a few times! 2018 Telsa MS
2012 Range Rover Sport HSE+
1990 Porsche 944
1985 LR 90 Soft top V8
Post #643008 Wed Jul 03 2024 1:25pm
Pistnbroke
United Kingdom 2009 Range Rover Sport TDV6 HSE Galway Green
Brilliant I have one ...
Put it on one of the top wheel studs . Put wheel in rough position and Lower the hub to align it just above the wheel hole then with a large screwdriver lever the tyre up from below and push it on EPLS Always listen to old people or when they die you will live on in ignorance.
The avatar is a picture of the man with a big cock.
Learned to 4x4 on 100 mile beach and Frazer Island QLD
Dont spend money on old cars you will never get it back
Post #643025 Thu Jul 04 2024 6:32am
JonnyCJ
I take it when you say “lower the wheel” you mean lower the hub with the jack ?
EPLS - took me a minute to get that, but will use it from now on !
Post #643027 Thu Jul 04 2024 7:10am
Pistnbroke
Yes me idiot...the trick is to lift the wheel the last 6mm with a lever under the tyre....if the tyre is not off the ground ( on the lever) you cannot push it in over the adaptor. the lever lifts and lets you push the tyre towards the hub VEPLS
your e bay link does not work.. This does
https://www.ebay.co.uk/itm/386210721184?it...R475xMaPZA Always listen to old people or when they die you will live on in ignorance.
Post #643028 Thu Jul 04 2024 7:21am
Mine came as a pair one long and one short, makes it so easy to align the studs without busting a gut.
Cheer
Post #643029 Thu Jul 04 2024 8:02am
JonnyCJ
Could you put the tool on with the slot horizontal and then put the screwdriver through the bolt hole and use the lever that way ?
Post #643030 Thu Jul 04 2024 8:31am
Pistnbroke
Why ? you have giggled the tyre towards the hub..lowered the hub to be almost aligned so just lift the tyre 6mm with a large screwdriver between the tyre and the ground .
But to answer the question YOU could do anything you want but why make life hard when its easy?
I have stopped watching this topic because the string of comments is just getting silly for so simple a bit of equipment Always listen to old people or when they die you will live on in ignorance.
Post #643031 Thu Jul 04 2024 8:47am
JonnyCJ
By levering the wheel on to the tool through the bolt hole (putting the screwdriver in the slot on the tool) you avoid the sharp edges of the tool scratching the paint at the rear of the bolt hole, as the weight of the wheel is taken up on the smooth screwdriver shaft.
I assumed that’s what the slot was for ?
Post #643032 Thu Jul 04 2024 9:47am
Pistnbroke
The slot is to undo it with a screwdriver if its too tight to un do by hand Always listen to old people or when they die you will live on in ignorance.
Post #643033 Thu Jul 04 2024 11:33am
MikeBell36269
Best trick i was told was to put the wheel on a shovel then you can use your foot to lift it and put studs in both hands free.
Post #643040 Thu Jul 04 2024 3:38pm
Pistnbroke
This is smaller ,cheaper and takes up less space than a shovel. Always listen to old people or when they die you will live on in ignorance.
Post #643041 Thu Jul 04 2024 3:42pm
jimbg
Rolling with laughter Rolling with laughter Rolling with laughter Thumbs Up 2023 P440e SE Dynamic on order -cancelled
2022 HSE Dynamic P400e
2006 HSE
Post #643042 Thu Jul 04 2024 4:13pm
