![]() | Home > Technical > Ground location for engine Control Module |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4934 ![]() ![]() ![]() |
Thought the engine control module was attached to the bulkhead under the bonnet along with the transfer box module and cooling fan assy.
Pistnbroke Member Since: 22 Sep 2020 Location: rugby Posts: 402 ![]() ![]() ![]() |
Thanks col ...Which side on a RHD ( ausie style) Where do I look ? Getting suspicious of a voltage drop affecting crank sensor supply /earth etc. Go for the simple stuff first. Always listen to old people or when they die you will live on in ignorance.
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8922 ![]() ![]() ![]() |
The engine ECU (and transfer box ECU) is behind the battery enclosure on a RHD vehicle. 2012 SDV6 - it's missing a couple of cylinders
Yes I had the battery out today to change it ..if I still get crankshaft sensor problems I will have to get in behind the front LH wheel and change it Always listen to old people or when they die you will live on in ignorance.
