Home > Technical > Ground location for engine Control Module
Pistnbroke
Trying to sort fault code for Crankshaft sensor problem . But have discovered the engine stops/limps only after going around a roundabout ie indicators on /footbrake ? low engine speed . Now first rule of auto electrics is if one circuit being operated affects another its an earth fault....I guess engine module is under drivers seat but does anyone know where the earth bolt is for the module?
Looking to check voltage at sensor today. Always listen to old people or when they die you will live on in ignorance.
Post #642895 Fri Jun 28 2024 7:32am
Thought the engine control module was attached to the bulkhead under the bonnet along with the transfer box module and cooling fan assy.
Post #642896 Fri Jun 28 2024 8:13am
Pistnbroke
Thanks col ...Which side on a RHD ( ausie style) Where do I look ? Getting suspicious of a voltage drop affecting crank sensor supply /earth etc. Go for the simple stuff first. Always listen to old people or when they die you will live on in ignorance.
Post #642897 Fri Jun 28 2024 8:55am
The engine ECU (and transfer box ECU) is behind the battery enclosure on a RHD vehicle. 2012 SDV6 - it's missing a couple of cylinders
Post #642901 Fri Jun 28 2024 12:40pm
Pistnbroke
Yes I had the battery out today to change it ..if I still get crankshaft sensor problems I will have to get in behind the front LH wheel and change it Always listen to old people or when they die you will live on in ignorance.
Post #642902 Fri Jun 28 2024 12:58pm
