Home > Technical > Air con pressure switch |
glendmc Member Since: 10 Mar 2024 Location: 44 Posts: 31 |
Hi you all, i am having some issues with my ac, it is not blowing cold and it is not leaking freon, it seem as if the compressor not staying on long enough so it will not get cold. Maybe the pressure switch is bad, i would like to check the pressure switch, can someone tell me how many switches are there and the location for 2015 rrs sdv6 autobiography. |
Wed Jun 26 2024 6:52pm |
Thank you for your reply, so you do not think that is the problem,what do you think it might be? any help is appreciated. I charged the system but not getting cold, not even the lines are cold. |
Thu Jun 27 2024 4:13am |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 937 |
Are you saying you charged the system yourself,, or you paid someone to do it??,, just trying to get all the facts laid out. 2010 RRS, TDV8
Fri Jun 28 2024 8:10pm |
yes i charged it myself, all it takes is a manifold, gas and a little know how. |
Sat Jun 29 2024 1:58am |
i just have a funny feeling the problem is the pressure switch, but don't know where to locate them compressor and clutch working fine, i pulled a vacuum and its not leaking, just will not get very cold, maybe something is blocking the flow. Will make an appointment with JLR and mortgage my house to pay for it. |
Sat Jun 29 2024 2:12am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4952 |
Sat Jun 29 2024 3:12am |
col, thanks for the diagram bro. i just saw it am really grateful for it. |
Tue Sep 24 2024 6:09pm |
Thanks again for the diagram pal, would you happen to know what that part number is, i will try replacing it and see if that is the promlem. |
Thu Sep 26 2024 4:06pm |
