Home > Technical > Air con pressure switch
glendmc
Jamaica
Hi you all, i am having some issues with my ac, it is not blowing cold and it is not leaking freon, it seem as if the compressor not staying on long enough so it will not get cold. Maybe the pressure switch is bad, i would like to check the pressure switch, can someone tell me how many switches are there and the location for 2015 rrs sdv6 autobiography.
Post #642861 Wed Jun 26 2024 5:52pm
On my old one there aren’t any switches.
A variable pressure sensor is fitted and a voltage is produced in relation to pressure. I doubt that is your issue
Post #642862 Wed Jun 26 2024 6:31pm
glendmc
Jamaica
Thank you for your reply, so you do not think that is the problem,what do you think it might be? any help is appreciated. I charged the system but not getting cold, not even the lines are cold.
Post #642870 Thu Jun 27 2024 3:13am
gogsy1956
Are you saying you charged the system yourself,, or you paid someone to do it??,, just trying to get all the facts laid out. 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #642919 Fri Jun 28 2024 7:10pm
glendmc
Jamaica
yes i charged it myself, all it takes is a manifold, gas and a little know how.
Post #642922 Sat Jun 29 2024 12:58am
glendmc
Jamaica
i just have a funny feeling the problem is the pressure switch, but don't know where to locate them compressor and clutch working fine, i pulled a vacuum and its not leaking, just will not get very cold, maybe something is blocking the flow. Will make an appointment with JLR and mortgage my house to pay for it.
Post #642924 Sat Jun 29 2024 1:12am
Post #642925 Sat Jun 29 2024 2:12am
glendmc
Jamaica
col, thanks for the diagram bro. i just saw it am really grateful for it.
Post #644374 Tue Sep 24 2024 5:09pm
glendmc
Jamaica
Thanks again for the diagram pal, would you happen to know what that part number is, i will try replacing it and see if that is the promlem.
Post #644425 Thu Sep 26 2024 3:06pm
