![]() | Home > Technical > Cat removal 2007 tdv6 |
NoExpert Member Since: 28 Jan 2022 Location: Poznań, Poland Posts: 453 ![]() ![]() ![]() |
What color smoke? 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1062 ![]() ![]() |
I would be looking at glow plugs - typical symptoms of failure leading to unburnt fuel and smoke on start. 07MY RRS TDV6
Pistnbroke Member Since: 22 Sep 2020 Location: rugby Posts: 402 ![]() ![]() ![]() |
Well I only got two glow plugs working and I get no smoke. 2.7 l Always listen to old people or when they die you will live on in ignorance.
Jellis39 Member Since: 21 Apr 2019 Location: Melton Mowbray Posts: 63 ![]() ![]() |
Defo fuel as it smells of diesel. 6 new glow plugs fitted recently. When coolant gets to 30 it’s perfect and a couple of revs clears smoke. I feel it’s injectors but they have just been tested as ok, but I know that’s not totally accurate. |
You can reduce the fuel on start up by fooling the computer its hotter than it actually is . 220K ohms across the eng temp sensor will reduce the fuel but not affect the temp gauge.
Yea I do that on my d3 with the resistor on a switch. Had a proper look today and after a run smelt diesel. Removed engine cover and found several high pressure pipe unions wet and on the ns fuel running onto turbo and exhaust manifold! Rang garage who have just done the injectors as I wanted the new owner to have it right and I just didn’t have time. Answer was see if they’ll tighten! Found several unions into injectors not fully tight into injectors, 2 high pressure pipes to injectors not fully tight on ns along with them slightly loose onto the rail not impressed so a call tomorrow will be made with a request to refund some of the bill. The smoke has reduced in startup and when it does a small blip in the throttle clears it. It’s less than my own d3! |
