Home > Maintenance & Modifications > Timing pin for Belt installation No Starter removal
Pistnbroke
United Kingdom 2009 Range Rover Sport TDV6 HSE Galway Green
Found this on ebay ...
Its the clone of the factory alignment pin and does not need the starter to be removed..
As seen on LR Time.
Item eBay Item No. 166793632634
https://www.ebay.co.uk/sch/i.html?_from=R4...;_osacat=0 Always listen to old people or when they die you will live on in ignorance.
The avatar is a picture of the man with a big cock.
Learned to 4x4 on 100 mile beach and Frazer Island QLD
Dont spend money on old cars you will never get it back
Post #642562 Tue Jun 11 2024 3:12pm
NoExpert
Where does that go in? I saw one video where he’s screwing in a timing pin, but it’s right where the power steering and A/C compressor mount. Highly curious since I’ll be working on mine shortly. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #642574 Wed Jun 12 2024 7:41am
Pistnbroke
Looking at the video they sent me its on the LHS of the engine about 3 in from the sump line..in the photo on ebay you can see one bolt remaining .thats the cap over the hole.
The critical thing is it must be the right length within 0.1mm and the pins are not 6mm but 5.8.
By the time you have got the fan and crank shaft pulley off maybe moving some thing out the way will be a lot easier than moving the starter motor and and the oil cooler which is in the way.
Its JLR nothings easy. Always listen to old people or when they die you will live on in ignorance.
Post #642576 Wed Jun 12 2024 8:17am
I’d stick to the usual method, unless the AC is off. (Not easy to remove compressor )
Post #642579 Wed Jun 12 2024 10:39am
