![]() | Home > Maintenance & Modifications > How do you remove plastic sill covers? |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 782 ![]() ![]() ![]() |
Have a look at this
Pistnbroke Member Since: 22 Sep 2020 Location: rugby Posts: 440 ![]() ![]() ![]() |
EXCELLENT THANKS Always listen to old people or when they die you will live on in ignorance.
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9050 ![]() ![]() ![]() |
They're dead easy to remove. |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5065 ![]() ![]() ![]() |
Always worth removing the bit that goes up the rear door post as well, and clean all the mud and crap out that builds up under that.
As Col says, you will be surprised how much muck gets in there. Probably worth getting some new clips before you take the wheel arch trim off, they're 15 years old and are probably a bit brittle by now. |
