Home > Maintenance & Modifications > How do you remove plastic sill covers? |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 778 |
Have a look at this
Tue Jun 11 2024 7:03pm |
Pistnbroke Member Since: 22 Sep 2020 Location: rugby Posts: 415 |
EXCELLENT THANKS Always listen to old people or when they die you will live on in ignorance.
Tue Jun 11 2024 8:48pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8987 |
They're dead easy to remove. 2012 SDV6 - it's missing a couple of cylinders
Tue Jun 11 2024 10:15pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4982 |
Always worth removing the bit that goes up the rear door post as well, and clean all the mud and crap out that builds up under that.
Tue Jun 11 2024 10:30pm |
As Col says, you will be surprised how much muck gets in there. Probably worth getting some new clips before you take the wheel arch trim off, they're 15 years old and are probably a bit brittle by now. |
Wed Jun 12 2024 3:50pm |
