Home > General > LR015144 - ACE Pipes |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5029 |
Nearly a grand, and people say LR dealers prices are a rip off.
Thu May 30 2024 7:58am |
Flinders Member Since: 12 Dec 2014 Location: West Yorkshire Posts: 126 |
They’ve dropped in price now. If I’d have to make a choice between waiting 7 months for parts or paying the extra £££’s I’d be paying the extra! Hopefully this is a sign parts are now starting to come back in stock! |
Thu May 30 2024 11:14am |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4419 |
4 sets in stock |
Thu May 30 2024 12:01pm |
JonnyCJ Member Since: 25 Apr 2011 Location: Wirral Posts: 416 |
Can the rigid pipes not be replicated with stainless braided nylon pipes similar for use in high pressure hydraulic applications ? Not sure what the fittings are at each end, but can’t be beyond the wit of man (or woman - thank you Reg). |
Sun Jun 02 2024 2:56pm |
There are some on here that have used hydraulic pipe with couplings to patch repair. Pirtek also supplied for temporary fixes to someone on here. Not sure how long term they would last?
Sun Jun 02 2024 5:56pm |
Meiang Member Since: 29 Apr 2011 Location: Perth Posts: 403 |
I dont know what you guys are doing - soaking the car in "sea water". The ace pipes should be designed for the life of the car. They surely cannot be leaking from internal corrosion. Its a 4WD, it should be able to take getting wet occassionally. |
Mon Jun 03 2024 6:25pm |
I would hazard a guess, the main issue is salt used on UK roads during the winter months is causing the majority of the corrosion, in addition to it getting trapped between the pipes and mounting brackets which seem to be where a lot of them fail.
Mon Jun 03 2024 9:41pm |
