Home > General > RRS SUPERCHARGED Chimes not working
Markieboy123
United Kingdom 2005 Range Rover Sport Supercharged Stornoway Grey
Hi All,
This has been bugging me for some time.
The audible warning chimes do not work on my sport, I know some will say that’s a blessing but i like the bing bong when I leave the lights on or door open.
As you know from my previous posts I had a few electrical issue due to the A pillars water ingress.
Think I have eliminated most of the suspect tape joint and corroded connectors.
Not much information on the internet about this fault however i believe the speaker is attached at the rear of the speedo cluster?
Also affects the parking sensors at the front. I know the PDC is working because the switch on the dash is illuminated and the rears emit a tone
Anyone else had this issue on their’s ?
Post #642025 Fri May 17 2024 4:25pm
Yeah. Instruments need repair.
There is a guide on the internet if your very handy and brave with a solder iron
Speaker change required
?si=9TPjztavSfKuX-cW
Random video
Post #642030 Fri May 17 2024 5:51pm
Markieboy123
Thanks again Andy…
Will whip the cluster out and have a look.
See a few sellers on Fleebay offering repair for around £150
Post #642031 Fri May 17 2024 6:56pm
T
England 2012 Range Rover Sport SDV6 HSE Santorini Black
I don't suppose this will work for your car, but just in case it does I saw this video ages ago and 'bookmarked' it.
It's got to be worth a try - someone may just have disabled yours in the same way.
Post #642045 Sat May 18 2024 8:05am
Markieboy123
I did try that, think it just affects the seat belt chime.
I have no alert tones or front parking tone
Post #642053 Sat May 18 2024 4:34pm
T
Ah! I see. In that case I can only offer you good luck in finding the problem . . .
Post #642054 Sat May 18 2024 5:17pm
Markieboy123
Thanks
Post #642056 Sat May 18 2024 7:00pm
