![]() | Home > Faults & Fixes > Updated - now diagnosed as splt inlet Manifold |
Iguana Member Since: 03 Feb 2024 Location: Somerset Posts: 26 ![]() ![]() |
Driving home tonight, lovely 55 mins of the usual joy, then 5 mins from home, car lurched, a big 'bong' followed by restricted performance and RR now sounding like a tractor |
NoExpert Member Since: 28 Jan 2022 Location: Poznań, Poland Posts: 493 ![]() ![]() ![]() |
I don’t think it’s terminal. Best bet is to get the codes read and have somebody put eyes on it. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
2 RRS Member Since: 04 Sep 2016 Location: Shropshire Posts: 174 ![]() ![]() ![]() |
Sounds very much like a fuel injector copper washer leaking, quite common and an easy and cheap fix!! |
Thanks all!
Update, it wasn't the injectors, huge split/hole in the inlet manifold, so needs a new manifold, which is on order, hopefully will get it back next week.
Maybe worth asking them while it's apart to do the other manifold too, it's not much more labour to do the 2. Would make sense to pay a small contribution now and not have to worry about the other side failing in the future as they are a common weak point up until 2016 model year when the manifolds were revised . |
Johnrrs Member Since: 16 Feb 2021 Location: Yorkshire Posts: 474 ![]() ![]() ![]() |
That’s good news for you as in my warranty small print the manifold isn’t covered. Just hope mine doesn’t fail…… |
Karlp606 Member Since: 25 Jun 2022 Location: East Yorks Posts: 269 ![]() |
Mine werent covered in the end!
