Home > Faults & Fixes > Updated - now diagnosed as splt inlet Manifold |
Iguana Member Since: 03 Feb 2024 Location: Somerset Posts: 25 |
Driving home tonight, lovely 55 mins of the usual joy, then 5 mins from home, car lurched, a big 'bong' followed by restricted performance and RR now sounding like a tractor
Wed May 15 2024 6:43pm |
NoExpert Member Since: 28 Jan 2022 Location: Poznań, Poland Posts: 453 |
I don’t think it’s terminal. Best bet is to get the codes read and have somebody put eyes on it. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Wed May 15 2024 7:59pm |
2 RRS Member Since: 04 Sep 2016 Location: Stafford/Telford Posts: 114 |
Sounds very much like a fuel injector copper washer leaking, quite common and an easy and cheap fix!! |
Wed May 15 2024 11:19pm |
Thanks all!
Wed May 15 2024 11:56pm |
Update, it wasn't the injectors, huge split/hole in the inlet manifold, so needs a new manifold, which is on order, hopefully will get it back next week.
Fri May 17 2024 1:13pm |
Maybe worth asking them while it's apart to do the other manifold too, it's not much more labour to do the 2. Would make sense to pay a small contribution now and not have to worry about the other side failing in the future as they are a common weak point up until 2016 model year when the manifolds were revised . |
Fri May 17 2024 1:22pm |
Johnrrs Member Since: 16 Feb 2021 Location: Yorkshire Posts: 431 |
That’s good news for you as in my warranty small print the manifold isn’t covered. Just hope mine doesn’t fail…… |
Fri May 17 2024 1:40pm |
Karlp606 Member Since: 25 Jun 2022 Location: East Yorks Posts: 214 |
Mine werent covered in the end!
Fri May 17 2024 2:04pm |
