Home > General > MY2010 headlight replacement lens |
T Member Since: 18 Feb 2024 Location: Isle of Wight Posts: 64 |
Not original and not tried by them, but there are these if you're stuck:
Tue May 14 2024 10:22am |
JonnyCJ Member Since: 25 Apr 2011 Location: Wirral Posts: 416 |
Found one - good old Powerful.
Tue May 14 2024 10:32am |
It’s definitely NOT the oven trick ! Ignore any vids etc which tell you to put MY2010 - 2013 headlights in the oven. The later facelift (andL322) lights use something similar to windscreen rubber, which doesn’t melt or soften when heated.
Tue May 14 2024 7:31pm |
All sorted. The sealant is called Betaseal and doesn’t soften. I’ve used a combination of screwdrivers, scalpel and Dremmel to clean out the channel after removing the old lens.
Thu May 16 2024 5:45am |
