![]() | Home > Technical > "Suspension will raise once system cooled" |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5036 ![]() ![]() ![]() |
There are 2 temperature sensors on the compressor
Gismo21 Member Since: 04 May 2024 Location: Shropshire Posts: 4 ![]() ![]() ![]() |
Thanks, Andy, We will do as you suggest and let you know the outcome. Cheers Nick |
UPDATE
Spring kits usually come with an electronics box to shut that up, I believe |
No such electronics box with the springs kit. |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4451 ![]() ![]() ![]() |
Did you replace the compressor only, or fit a full kit with covers + bracket? |
