Home > Technical > "Suspension will raise once system cooled"
Gismo21
United Kingdom 2010 Range Rover Sport 3.0 TDV6 S Galway Green
Hi Guys, I'm new on here so please be gentle....
Ok we had the dreaded "Suspension will raise once system cooled"
RR Sport V8 2010 L320
No lift at all.
Replaced the Compressor with a new AMK unit
No lift, no power to the compressor
Same notice "Suspension will raise once system cooled"
Gave the compressor some external voltage, and all four corners lifted!
RR on the ramp so we checked for leaks and couldn't find any.
Powered up the old compressor on the bench and it worked fine.
We still have the "Suspension will raise once system cooled" with the compressor not wired up..
We are going to replace the AIR SUSPENSION CONTROL MODULE ECU
Otherwise, we are completely out of ideas.
Post #641704 Sat May 04 2024 11:04am
There are 2 temperature sensors on the compressor
As you have changed them with no improvement , I would say you have a wiring fault between the compressor and ecu (by pedals) in the 4 temperature sensor wires.
P.s. if you have changed from one brand of compressor to AMK you will need to reprogram, otherwise damage will eventually occur.
So maybe refit old one if you can’t program, once you have fix the temp sensor issue
Post #641705 Sat May 04 2024 11:50am
Gismo21
Thanks, Andy, We will do as you suggest and let you know the outcome. Cheers Nick
Post #641706 Sat May 04 2024 12:34pm
Gismo21
UPDATE
We changed the air compressor and module and it generated a hell lot of codes. We then changed back to the original compressor and module and nothing happened. No suspension.
We spoke with Land Rover who offered no help.
So we have opted to remove the air suspension and have fitted shocks and coil springs which I must say is a lovely ride and handling.
The problem is how to remove the fault warnings off the dash relating to the now removed air suspension? Is there software available to do this as OBD2 wont touch it.... Thanks in advance Nick
Post #642170 Thu May 23 2024 8:58am
Spring kits usually come with an electronics box to shut that up, I believe
Post #642171 Thu May 23 2024 9:02am
Gismo21
No such electronics box with the springs kit.
Post #642172 Thu May 23 2024 9:05am
Disco_Mikey
Re: "Suspension will raise once system cooled"
No lift at all.
Did you replace the compressor only, or fit a full kit with covers + bracket?
Post #642182 Thu May 23 2024 1:07pm
