Home > General > How to get this part out |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8971 |
Is this the inlet plenum for a TDV8? If so, that's the device that deactivates one of the inlet ports to give better low end performance. It's also connected to a pipe that runs to the filter box.
Wed May 01 2024 5:35pm |
JonnyCJ Member Since: 25 Apr 2011 Location: Wirral Posts: 347 |
Yep - 3.6 TDV8 and is the same part you’ve identified. Looks purely mechanical to me, so wouldn’t envisage a good cleaning would do any harm, especially as it’ll get fully lubricated within about 5 mins if driving.
Wed May 01 2024 6:23pm |
peterjj Member Since: 15 Mar 2017 Location: Canberra Posts: 48 |
This actuator is connected to a butterfly valve type flap that is usually open ie left\right in your photo but the space in the manifold to get it out is a slot that goes 90deg to that. You need to push the vacuum actuator in to close the flap so it aligns with the slot hole in the manifold so you can wriggle and lift out actuator and arm and valve all at once (after screws have been remove of course) Pete
Wed May 01 2024 10:46pm |
Actually, this bit controls balance between left and right intake manifolds (item2). The port deactivation actuators look similar but are at the rear end of each intake manifold thing (item7). Pete 2008 L320 TDV8 2022 Hilux Rugged-X |
Wed May 01 2024 10:52pm |
Great knowledge - many thanks Peter ! |
Thu May 02 2024 5:51am |
Ah, yes, you're right now I've looked at it again. Posted in haste originally. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Thu May 02 2024 5:27pm |
Had a go at this today, albeit briefly. Didn’t manage to get it out. I think it’s a bit like picking a lock, in that the flap needs to align exactly with the slot.
Thu May 02 2024 5:55pm |
yep, the actuator arm goes into the actuator. Pete
Thu May 02 2024 10:37pm |
