![]() | Home > Technical > Handbrake question after body removal. |
savi18 Member Since: 02 Aug 2015 Location: Gore. South Island NZ Posts: 148 ![]() ![]() |
Hi Team, 12 months ago had new engine fitted to my 2009 2.7 v6 RRS, when they remove the complete body where do they disconnect the handbrake cable from do they leave the module in place and disconnect from the wheel side and hand brake switch, I’m was going to adjust the rear hand brakes shoes but if they removed the rear cables from wheels then they would most probably set the adjustment up. Cheers |
Thankyou. |
