Home > General (L494) > Towing Software?
RRS?
Towing Software?
I’ve noticed on my new to 2015 RRS that I don’t have the line on my camera that aims for the tow hitch on my caravan.
Is this something that’s done with a software update or done as part of a package when the car was specced? Or is it something I can do with my IID Tool?
Coming from a discovery 4 where you could see your tow ball I’m missing the aid!! 2004 D3 HSE TDV6
2011 D4 HSE SDV6
2015 L494 RRS Autobiography SDV6
Post #641094 Thu Apr 11 2024 4:35am
PhilMid
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Bali Blue
If you tap the screen you should have icons which turn on the tow hitch assist line and the car parking asssist lines
Post #641123 Thu Apr 11 2024 1:04pm
SpiderPig
I'm pretty sure that the trailer tow assist is an optional extra. Whether this can be retro-fitted is something I have no idea about. 2021 P400e Autobiography
Post #641124 Thu Apr 11 2024 1:06pm
PhilMid
Tow assist and the lines to help hitch up are different things. The OP was asking about the line to assist the hitching of a trailer/caravan, not tow assists that aids when towing.
Post #641127 Thu Apr 11 2024 1:30pm
RRS?
Thanks for the help and suggestions, I don’t have an option on my camera for the hitch line though?
 2004 D3 HSE TDV6
2011 D4 HSE SDV6
Post #641129 Thu Apr 11 2024 2:11pm
Russtyp
The GapIID can enable this function
Post #641133 Thu Apr 11 2024 8:35pm
RRS?
Perfect, do you know where I need to be looking? 2004 D3 HSE TDV6
2011 D4 HSE SDV6
Post #641135 Fri Apr 12 2024 4:52am
Russtyp
You need to contact Pat at Gap and ask for access to the unconfirmed list.
I then searched for tow and it came up with a couple of options
I enabled towbar, trailer tow ball and trailer stability assist.
It then gives you the option on rear camera for tow ball.
I don’t use it as you still can’t see the tow ball so still have to guess.
Post #641138 Fri Apr 12 2024 7:18am
Notyalc
You should get a RED dot which is where the ball is.
You should not have to guess.
Post #641152 Fri Apr 12 2024 4:03pm
Russtyp
I agree you do get a red dot showing where the tow ball should be.
But because of the angle the camera is you loose sight of the end of the hitch.
When it gets close. That’s why I said you have to guess.
Post #641154 Fri Apr 12 2024 7:08pm
Notyalc
I get spot on under the hitch every time.
Maybe I’m lucky…
Post #641155 Fri Apr 12 2024 7:24pm
