![]() | Home > Technical > Map updates from Here on USB |
RRT Member Since: 26 Mar 2018 Location: South Coast Posts: 252 ![]() ![]() |
Using a fast internet connection the download takes between 20 minutes and 1 hour (plus) and is circa 33GB
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5036 ![]() ![]() ![]() |
?si=dH52KtPU-iFHGter |
SpiderPig Member Since: 13 Mar 2024 Location: Herefordshire Posts: 121 ![]() ![]() |
Yeah, it takes a damned sight longer to download than it does to update the maps in the car! I just start the update and then leave the car on the drive with the update running (thankfully I live on a quiet street and can see the car from where I’m working in the house).
jimbg Member Since: 29 Jan 2013 Location: By the River Dart Posts: 1875 ![]() ![]() |
You can check the current state of roads on the "master" map and also upload changes to HERE.
RRSSDV8 Member Since: 26 Jan 2024 Location: Cheshire Posts: 38 ![]() ![]() ![]() |
thanks everyone, so do you need to leave the car running while the updates are taking place then? |
Yes, car should be running as far as I'm aware.
Yes, I do the update when during any 30 minute drive I make. 2023 P440e SE Dynamic on order -cancelled
