Home > Maintenance & Modifications > Range rover l322 4.2 supercharged engine swap into a l320?!
Scottj640
United Kingdom 2005 Range Rover Sport TDV6 HSE Zambezi Silver
I have a pair of 2006 range rovers...one is rusty beyond repair and one with a couple melted pistons. I have both engines out and wanna swap over! I know the sump and wiring looms are different but anyone know is there anything else that is going to catch me out or need changing?! I have nothing vehicle's side by side and both motors opposite siswd of workshop but as I have done all this with body on and box in I wanna get it right first time lol. 🙏
Post #640568 Thu Mar 21 2024 2:06am
Zixt
Hi Scott
We're looking at doing the same! How did you get on?
Post #645136 Thu Nov 07 2024 10:40pm
At a guess accessories like the suspension pump and mounting and air con compressor etc. will be different. and wiring loom etc
But there must be a difference for the engine number.
I'm sure you can make use of the mechanical bits and heads though.
Post #645140 Fri Nov 08 2024 10:12am
Zixt
So... we ended up doing it!
It can definitely be done - we did have to use the exhaust manifold and mounts off the original engine, but everything swapped over pretty easy.
She is now back up and running.
Post #645516 Thu Nov 28 2024 11:50am
Engine swap
Australia
Hey mate I'm currently swapping engines, I have two 4.2 supercharged engines both out of 2006 range rover sports. the one I'm removing is no good do you think I can put the good engine in without any problems any information would be greatly appreciated cheers for australia
Post #645618 Wed Dec 04 2024 3:29pm
Zixt
If it's the same engine and same type donor vehicle can't imagine you'd have a problem.
Post #647144 Mon Mar 03 2025 1:38pm
