![]() | Home > Technical > Rattle at rear cured for $0 |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9049 ![]() ![]() ![]() |
At last, a low cost repair of yours that I agree with entirely. |
Sham91 Member Since: 24 May 2018 Location: Bradford Posts: 178 ![]() ![]() ![]() |
How much did you turn them by? fully or a little? RRS TDV6 2010 ![]() |
Pistnbroke Member Since: 22 Sep 2020 Location: rugby Posts: 438 ![]() ![]() ![]() |
Maybe 8mm . If you look up under the joint top to bottom tailgate you will see there is a gap so no rubbing. Also the close is a rubbery thud rather than metallic. Always listen to old people or when they die you will live on in ignorance.
