Home > General > Side steps removal |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 778 |
The trims you will have fitted have cut outs in them to accommodate the brackets. I you don't replace the steps you will need some uncut sill covers, you will need to remove them to take the brackets off in any event. |
Fri Mar 01 2024 2:41pm |
JonnyCJ Member Since: 25 Apr 2011 Location: Wirral Posts: 347 |
Much appreciated ! |
Fri Mar 01 2024 2:55pm |
Done a bit of searching, but can't seem to find the part nrs for the sill trims. Anyone happen to know where to find them ?
Fri Mar 01 2024 4:48pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4968 |
R/H LR018175 or old no. DPG500521PCL, L/H LR018176 or DPG500531PCL. Find some S/H ones if needed as stupid money as usual from L/R best part of two hundred quid each. If they are original pre-cut one's or some one made a decent job of the cut-out's you may not even need to replace them as the cut-out's may be underneath out of site.
Fri Mar 01 2024 9:06pm |
Smashing - thanks Col. An uncut pair sourced for £40 delivered.
Fri Mar 01 2024 9:49pm |
Steps removed and despite not being very old, we’re in very poor condition. I have to say, I do prefer the look without them - much sleeker and shows off the lines much better.
Tue Mar 26 2024 6:58pm |
Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1251 |
I also did mine last year as they'd lasted 6 years. 100% agree on the looks without them. I can't see me adding them again.
Tue Mar 26 2024 9:19pm |
Some nice work in your gallery Steve - envious of the lift !
Tue Mar 26 2024 9:32pm |
I had mine serviced last Wednesday and they washed it. The roads around here with the farming activity at the mo means the roads are brown. There's not a clean car about 2006 2.7 TDV6 HSE in Cairns Blue. |
Wed Mar 27 2024 6:18am |
