Home > General > Side steps removal
JonnyCJ
Side steps removal
I’m contemplating removing my side steps as they’re a bit tatty and I prefer the look.
Is there any trim that I would need to have to cover anything up once they’re off ?
Post #640089 Fri Mar 01 2024 10:21am
Oldandconfused
The trims you will have fitted have cut outs in them to accommodate the brackets. I you don't replace the steps you will need some uncut sill covers, you will need to remove them to take the brackets off in any event.
Post #640093 Fri Mar 01 2024 2:41pm
JonnyCJ
Much appreciated !
Post #640094 Fri Mar 01 2024 2:55pm
JonnyCJ
Done a bit of searching, but can't seem to find the part nrs for the sill trims. Anyone happen to know where to find them ?
Many thanks !
Post #640098 Fri Mar 01 2024 4:48pm
R/H LR018175 or old no. DPG500521PCL, L/H LR018176 or DPG500531PCL. Find some S/H ones if needed as stupid money as usual from L/R best part of two hundred quid each. If they are original pre-cut one's or some one made a decent job of the cut-out's you may not even need to replace them as the cut-out's may be underneath out of site.
Post #640107 Fri Mar 01 2024 9:06pm
JonnyCJ
Smashing - thanks Col. An uncut pair sourced for £40 delivered.
I was toying with keeping mine but prefer to keep as much mud and crud out or that area as possible.
Jonny
Post #640108 Fri Mar 01 2024 9:49pm
JonnyCJ
Steps removed and despite not being very old, we’re in very poor condition. I have to say, I do prefer the look without them - much sleeker and shows off the lines much better.
Whilst underneath I was extremely impressed with the underside condition of my car. Testament to its early life in Singapore.
Post #640723 Tue Mar 26 2024 6:58pm
Stevepd
I also did mine last year as they'd lasted 6 years. 100% agree on the looks without them. I can't see me adding them again.
Have a look in my gallery and you can see how rusty they can get. It's a very thin gauge 2006 2.7 TDV6 HSE in Cairns Blue.
Post #640728 Tue Mar 26 2024 9:19pm
JonnyCJ
Some nice work in your gallery Steve - envious of the lift !
Was toying with replacing my SC but thinking I’m going to spend a bit of money making it look stunning again. It’s been 9 months since it was washed…
Post #640731 Tue Mar 26 2024 9:32pm
Stevepd
I had mine serviced last Wednesday and they washed it. The roads around here with the farming activity at the mo means the roads are brown. There's not a clean car about Very Happy 2006 2.7 TDV6 HSE in Cairns Blue.
Post #640736 Wed Mar 27 2024 6:18am
