Home > Faults & Fixes > 2010 Cruise control speeds up on its own
Datsun770
Hi all
I've seen this mentioned before with people complaining that the car itself speeds up on its own. I don't have this problem but I do have an issue when I set the cruise control to say 70mph it will maintain that sometimes however will always then start speeding up until I press the brakes or cancel the cruise.
Car was previously accident damaged, front end where air bags were deployed around 5 years ago and has the autobiography kit added during repair (not me) so wonder if something could be effecting thus as a result.
No warnings or error messages. All appears to work as it should until it drops a gear and takes off past the speed limit without asking it to.
Any common faults I could check from your guy's experience?
Thanks
Post #640083 Fri Mar 01 2024 8:06am
Disco_Mikey
EPB module not mounted correctly on the chassis Thumbs Up
Post #640090 Fri Mar 01 2024 1:04pm
