![]() | Home > Technical > Coolant temperature |
Pistnbroke Member Since: 22 Sep 2020 Location: rugby Posts: 438 ![]() ![]() ![]() |
Should be half way indicating about 86 deg C ( thermostat 82 +4 )
mark8815 Member Since: 12 Nov 2023 Location: West Yorkshire Posts: 22 ![]() ![]() ![]() |
I realised adding a photo probably made it easier 😂🤦🏼♂️ like I said, most likely me being paranoid, I just don’t usually pay it much attention but I’ve now got it in my head it’s higher than usual
Slightly higher than I would expect . Always listen to old people or when they die you will live on in ignorance.
There will be slight veriations due to the temp sensor aging so you could put a new one in or just ignore it Always listen to old people or when they die you will live on in ignorance.
