Home > General > Steering wheel adjustment button snapped off! |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4966 |
I would think you remove the column shroud, and then push it out from the rear. |
Sun Feb 04 2024 7:40pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4982 |
As they only push in and are held in place by a couple of spring clip integrated in to the switch, and as you have already broken the switch it may be worth using something like a thin bladed screwdriver to try and pop the old one out first before removing the trim shroud, the switch is a funny shape so you might have to wiggle it a little bit to get it out. Unfortunately L/R are not renowned for allowing any excess wiring length, so might have a problem disconnecting the plug if you can get it out this way.
Sun Feb 04 2024 8:03pm |
