Home > General > Steering wheel adjustment button snapped off!
stevebracey30@gmail.com
United Kingdom 2012 Range Rover Sport SDV6 HSE Stornoway Grey
Hi all - I have a 2012 Range Rover sport hse , and last night my knee caught the steering wheel adjustment button and broke it off 😡. Now I think I have found a replacement one on eBay for £15 but after having a look in the car in the daylight I have 1 question - how the hell do you get the old one out??
It lays flat against the steering column - do I have to take it all apart as it looks like a plug and play part ? Any help would be welcomed .
Thanks - Steve Bracey.
Post #639360 Sun Feb 04 2024 11:34am
I would think you remove the column shroud, and then push it out from the rear.
Post #639375 Sun Feb 04 2024 7:40pm
As they only push in and are held in place by a couple of spring clip integrated in to the switch, and as you have already broken the switch it may be worth using something like a thin bladed screwdriver to try and pop the old one out first before removing the trim shroud, the switch is a funny shape so you might have to wiggle it a little bit to get it out. Unfortunately L/R are not renowned for allowing any excess wiring length, so might have a problem disconnecting the plug if you can get it out this way.
Post #639376 Sun Feb 04 2024 8:03pm
