Home > General > EPB Failure happened today - what to expect next?
Josh95
Northern Ireland 2012 Range Rover Sport 3.0 TDV6 HSE Java Black
So I never had issues with this before. I always use the parking brake. Applied it today, got out of the vehicle and locked it up. As soon as I locked it up, I got the squeal of death.
Got back into the car to see what was up. Pressed to release the parking brake and fault light appeared along with that squeal again. Tried moving the car forwards and backwards but the back wheels seemed to be locked.
AA came out to try and fix it. They pulled the release chord under the cup holders but it did nothing whatsoever. It’s now going to be toed to the garage I use to get repaired.
What kind of repair am I expecting to pay here?
Post #639352 Sun Feb 04 2024 2:46am
Sputty37
England 2012 Range Rover Sport SDV6 HSE Lux Baltic Blue
Mine done exact the same last night when I went to leave off work. Look forward to hearing everyones comments Sad
Post #639397 Mon Feb 05 2024 12:34pm
Kevin-t
Not sure if same problem!
However had my handbrake stuck on a couple of weeks ago. Was out of town at the time, a real pain in the neck. Two mornings on the trot....-6 degrees where I was also.
Anyway, called RAC second morning.
Seems Park brake actuators are prone to cracking. Rac guy disconnected them I got home without them. No Big deal.
My mechanic, took em off inspected them both, yes both cracked.
Replaced with new. Jobs a good en.
Approx £90 each for actuators, around one hour mechanic for removal, fitting and software check.
Happy guy.
Might be your probs, might NOT be. just my experience lately.
Thumbs Up Thumbs Up Thumbs Up Rangerover Sport 2016 4.4 sdv8 A/B loire blue.
Post #639399 Mon Feb 05 2024 12:53pm
bmszabo
Netherlands 2013 Range Rover Sport 3.0 TDV6 Autobiography Orkney Grey
A bit off-topic, out of interest.
What is the purpose of using the handbrake in this car (except when on a ferry boat)? IMHO putting the gear in "P" just does the same. Do I miss something? 😊
Post #639400 Mon Feb 05 2024 12:59pm
A 2016 is a different setup.
There is a guide here, on how to get the park brake module working again.
Not fun, but cheaper than £500? for a new unit.
https://www.disco3.co.uk/forum/epb-repairunjam-relatch-91299.html
Guides to setup and maintain the rear brakes :
https://www.disco3.co.uk/forum/bodsy-brake...ight=bible
http://tinyurl.com/brakebible
Post #639401 Mon Feb 05 2024 1:00pm
Kevin-t
This is why I use mine.
Post #639404 Mon Feb 05 2024 1:25pm
