Home > General > Rain coming in! |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4966 |
Is that the windscreen A pillar?
Sat Dec 30 2023 2:04pm |
andrew kennedy Member Since: 27 Apr 2010 Location: brittany Posts: 324 |
Thanks for that Andy. As I am off to Spain tomorrow. What if I were to put some Blue Tack round the pillar? Do you think that might sort it out pro-tem? Andrew Kennedy |
Sat Dec 30 2023 2:14pm |
Andy - I think I misunderstood what you meant by "pillar". I think now you were referring to is the pillar between the two side windows? My leak is on the pillar running up at an angle from the bonnet up to the car roof. Does that one simple prise off? cannot see a way of getting if off. Andrew Kennedy |
Sat Dec 30 2023 4:44pm |
skid1963 Member Since: 24 Mar 2018 Location: Snodland Posts: 208 |
2015 L494 SDV6 3.0 HSE Loire Blue 2006 L320 4.2 Supercharged 2009 BMW X5 M-Sport - Gone 2007 L320 2.7TDV6 SE Buckingham Blue - Gone 2011 Jaguar XFS 3.0V6 Diesel - Gone 2009 (59) L320 Facelift 3.0TDV6 HSE White Wrap - Gone 2008 BMW X5 M-Sport - Gone 2005 Audi A6 3.2V6 Quattro S-Line - Gone |
Sat Dec 30 2023 5:17pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4982 |
Just pop out the small oval airbag grommet, unto torx headed screw underneath, pull out a little as there are a couple of plastic pins that locate in the bodywork, lift slightly should then come off. The torx screw will proabaly stay in the trim as it is gripped by a couple of plastic lugs.
Sat Dec 30 2023 8:14pm |
The windscreeen pillar is held on with one bolt under the airbag logo. As previously stated.
Sat Dec 30 2023 9:13pm |
Could remove the trim and get someone to spray a hosepipe over the area outside while looking from inside, might prove something.
Sat Dec 30 2023 9:25pm |
Had one hell of a storm last night and the water is really coming in now. I'm going to tape over the factory fitted roof rails in the hope that will solve the problem. When I get back (or maybe when I am on holiday) I'll take the rails off and have a look round - cant find anything online re how to take them off but I presume it just a matter of taking off the black round blanks and taking off a couple of screws???? Andrew Kennedy |
Sun Dec 31 2023 7:19am |
Water "coming in" saga continues..........
Sun Dec 31 2023 12:27pm |
Lrstaylor Member Since: 10 Mar 2022 Location: Kent Posts: 348 |
Iv just done my sunroof drain on passenger side where water was filling up the Foot well.
Sun Dec 31 2023 2:03pm |
Sunroof drain tubes probably need sealant applying and putting back into the sunroof tray. |
Sun Dec 31 2023 2:30pm |
Not the best picture, might have to drop headlining a bit to get to it.
Sun Dec 31 2023 7:32pm |
RAIN COMING IN ...solved! One of the drain pipes situated in the "sunshine roof" cutter had become 'kinked' and was allowing water to come in on the head lining near the door pillar. Andrew Kennedy |
Tue Jan 09 2024 4:00pm |
Result well done on finding that |
Tue Jan 09 2024 5:09pm |
