Home > Technical > Hard Suspension / variable damping
aln101
Scotland 2012 Range Rover Sport SDV6 HSE Lux Orkney Grey
Thanks for all the input.
I found the suggested tyre pressures a little hard for even wear, and have settled in at about 32 front and 34 rear. with maybe 36 rear if loaded.
I have inspected all the bushes (with a prybar etc) and they are all centred and about the right amount of squashy.
They wouldn't have much effect on vertical movement anyway.
I don't have access to a adequate fault code reader yet, just the basic stuff. Gap coming soon. Haven't seen any warnings since I got it nearly a year ago.
Alan Series 3 109
Classic 2-door
101FC GS
Three P38 4.6L
RRS mk1 2012
Post #638258 Fri Dec 22 2023 2:36am
aln101
Forgot to mention-
There aren't too many sports about here, so haven't managed to compare.
One slightly earlier vehicle I know of, which I guess would have damping somewhere in between hard and soft on the CVD.
Friend has a Disco3, which is a much nicer ride.
Alan Series 3 109
Classic 2-door
101FC GS
Three P38 4.6L
RRS mk1 2012
Post #638259 Fri Dec 22 2023 2:42am
I tend to run 33 Front and 36 Rear for normal load and find it works fine for me personally, taking into account the pressure will go up slightly when tyres warmed up anyway.
Post #638260 Fri Dec 22 2023 4:09am
aln101
Ok then. Tyres about as good as we can get, so back to the dampers Rolling Eyes
If they default to hard, is there a way of finding out whether they are still able to adjust to soft?
If one of the terrain settings gets soft damping, I suppose I could drive repeatedly over the same pothole or speedbump while changing the setting Laughing
I doubt a fault would be logged, as the system wouldn't be aware of a problem unless there was a break in continuity somewhere at or in a damper, in which case an error message would show on the dash?
Alan Series 3 109
Classic 2-door
101FC GS
Three P38 4.6L
RRS mk1 2012
Post #638273 Sat Dec 23 2023 12:07pm
If you were expecting Range Rover ride, you've come to the wrong place. The L320 RRS isn't a Range Rover other than in its badges. It's a Discovery with suspension tuned to be more capable across a fast road. Ergo, it has firmer damping.
Air suspension is known for having some harsh secondary ride characteristics and there's nothing that can be done about that. It's still more supple than a coil-sprung ground missile from the likes of the German marques. 2012 SDV6 - it's missing a couple of cylinders
Post #638290 Sat Dec 23 2023 9:08pm
