![]() | Home > Technical > Suspension fault - error C1A13-64 |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9025 ![]() ![]() ![]() |
That does sound like the exhaust valve in the compressor (or some part of the tubing from it) is blocked/failed. 2012 SDV6 - it's missing a couple of cylinders
ShouldHaveStuckWithAudi Member Since: 20 Nov 2023 Location: Godstone Posts: 32 ![]() ![]() ![]() |
Ok, final update on this one...eventually got the bracket off and the old compressor out. Put a cheap (£75 from Amazon) replacement one in while i try to rebuild the original. A £2 collet in the male hex quick connect stud wouldn't hold so i was getting the C1A20 - Pressure Increase Too Slow When Filling Reservoir.
83series3 Member Since: 19 Sep 2021 Location: South East Kent Posts: 50 ![]() ![]() ![]() |
Try it with the car in neutral and the handbrake off … the increase / decrease in suspension height slightly changes the wheelbase length for some scientific reason that I cannot fathom on a Sunday evening |
Funny enough, I noticed that exact same thing.... Is a bit smoother when it has 'room to move'... But was still clunky.
The bushes on a 2009 are going to be a bit worn by now so some creaking isn't unexpected. As for uneven rise, I think that's a classic "they all do that, sir". |
