Home > Maintenance & Modifications > L320 under tray bolts
Cpt Jack Sparrow
Wales 2013 Range Rover Sport SDV6 HSE Fuji White
Hi all. Tried a search but to no avail.
Tried to remove the under trays today on my 2013 L320 to change the turbo drain pipe to the shorter one.
And that's as far as we got... Tried... Rolling with laughter
Not one bolt under there would budge, even with a breaker bar. Seems to me that the bolts have not been off for 10 years... Shocked
Any secrets out there to get them off, feels like they will either round over or snap, either way I think every one is going to have to be drilled out.
happy to take advice Whistle
CJS
Post #637763 Fri Dec 01 2023 5:10pm
Pistnbroke
United Kingdom 2009 Range Rover Sport TDV6 HSE Galway Green
someone must have had them off to change the oil ....or not
heat from a propane torch may shift them Always listen to old people or when they die you will live on in ignorance.
The avatar is a picture of the man with a big cock.
Learned to 4x4 on 100 mile beach and Frazer Island QLD
Dont spend money on old cars you will never get it back
Post #637765 Fri Dec 01 2023 5:19pm
Cpt Jack Sparrow
Tried heat...
Oil comes out the top with a vacuum pump for oil change, Wink
CJS
Post #637767 Fri Dec 01 2023 5:26pm
Have you tried soaking them in penetrating oil for a couple of day's, then use a good six sided socket and impact wrench. Buy a tin of copper slip as well when they go back.
Post #637772 Fri Dec 01 2023 6:59pm
Cpt Jack Sparrow
Thanks Col, that's my next approach....
Post #637775 Fri Dec 01 2023 7:31pm
TTR
United Kingdom 2012 Range Rover Sport 3.0 TDV6 HSE Santorini Black
Eh up
Good luck - I had the same issue if you look at my threads - turned into a saga 🤬😂
For what it’s worth it ultimately worked out quicker for me to grind off , drill out and retap.
I was there for days trying to get the little front piece off - funny now but not then🤬
I replaced all mine with stainless bolts and copper ease to boot.
Hope you get em shifted there a real PIA for what should be a simple job
Post #637777 Fri Dec 01 2023 8:21pm
Cpt Jack Sparrow
Ah yes now you say it, I remember your thread... Bow down
Post #637779 Fri Dec 01 2023 8:40pm
Cpt Jack Sparrow
Thread revival and update.
Decided to try and tackle this job again. Over the past 3 weekends I have been soaking the 10 bolts with penetrating oil.
Today I got under with an impact socket and 20" socket bar. 9 of the 10 cracked loose with a good dose of persuasion.
The last had been rounded completely by a previous owners attempt. so as a last challenge a took an old socket one size to small bashed it on with a hammer and went for it, to my surprise in gave in to me first time.
That's job done, going to replace all 10 with new bolts. Thumbs Up Thumbs Up Thumbs Up
Post #643396 Sun Jul 21 2024 8:48pm
Grimble
For damaged hex heads, as a last resort, if you have a Dremel, get some carbide tips, its fairly easy to then re-cut a hex, the next size down. The next size down may well be Imperial/AF.
Always use full hex sockets as well. RRS HSE Dynamic SDV6 2014
Nemo mortalium omnibus horus sapit
Post #643399 Mon Jul 22 2024 8:20am
Cpt Jack Sparrow
Well I finally gave in on this job and put the Car into Protec 4x4 just outside Cardiff
turns out the starter motor bolts were seized solid too, would never have got the job done lying on my back on the drive.... Rolling with laughter
Job done car back, issues resolved, 10/10 for Prtotec 4x4 customer service to, highly recommended.
Thumbs Up Thumbs Up
Paul
Post #644943 Mon Oct 28 2024 8:10pm
TTR
Eh up,
Glad you got it sorted, take it you’ve swapped to stainless bolts now for the under trays 🤔👍
Will save you hours in the future
Post #644945 Mon Oct 28 2024 8:21pm
