Home > Maintenance & Modifications > L320 under tray bolts |
Cpt Jack Sparrow Member Since: 07 Sep 2016 Location: Cardiff Posts: 111 |
Hi all. Tried a search but to no avail.
Fri Dec 01 2023 6:10pm |
Tried heat...
Fri Dec 01 2023 6:26pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4938 |
Have you tried soaking them in penetrating oil for a couple of day's, then use a good six sided socket and impact wrench. Buy a tin of copper slip as well when they go back.
Fri Dec 01 2023 7:59pm |
Thanks Col, that's my next approach.... |
Fri Dec 01 2023 8:31pm |
TTR Member Since: 14 May 2023 Location: West Yorkshire Posts: 152 |
Eh up
Fri Dec 01 2023 9:21pm |
Ah yes now you say it, I remember your thread... |
Fri Dec 01 2023 9:40pm |
Thread revival and update.
Sun Jul 21 2024 9:48pm |
Grimble Member Since: 21 Aug 2020 Location: Staffordshire Posts: 250 |
For damaged hex heads, as a last resort, if you have a Dremel, get some carbide tips, its fairly easy to then re-cut a hex, the next size down. The next size down may well be Imperial/AF.
Mon Jul 22 2024 9:20am |
