Home > General (L494) > Error Code 1CA20 Help
41664166@online.no
Norway 2006 Range Rover Sport TDV6 Autobiography Rimini Red
Have then had the codes read out at a workshop, and it shows C1A99-1C, Any tips on what it could be
Post #638754 Sat Jan 13 2024 7:23am
41664166@online.no
No one has come across this code
Post #638842 Mon Jan 15 2024 8:05pm
Post #638844 Mon Jan 15 2024 8:51pm
41664166@online.no
Replaced today the valve block on the right side at the back, this code disappeared but a new C1A13-64 appeared
Post #638878 Tue Jan 16 2024 8:12pm
Double check you have refitted the pipes correctly, as amongst other things it mentions pipes fitted incorrectly as well as the exhaust valve stuck/restricted.
Post #638881 Tue Jan 16 2024 8:58pm
41664166@online.no
Hello, then I changed the exhaust valve on the compressor, deleted all error codes and everything seems to work as it should. Thanks to everyone who contributed input. Good forum. Have a nice RRS day
Post #638914 Thu Jan 18 2024 10:49am
