![]() | Home > General (L494) > Error Code 1CA20 Help |
41664166@online.no Member Since: 01 May 2015 Location: Moss Posts: 128 ![]() ![]() ![]() |
Have then had the codes read out at a workshop, and it shows C1A99-1C, Any tips on what it could be |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5043 ![]() ![]() ![]() |
Cheers Col |
Replaced today the valve block on the right side at the back, this code disappeared but a new C1A13-64 appeared |
Double check you have refitted the pipes correctly, as amongst other things it mentions pipes fitted incorrectly as well as the exhaust valve stuck/restricted.
Hello, then I changed the exhaust valve on the compressor, deleted all error codes and everything seems to work as it should. Thanks to everyone who contributed input. Good forum. Have a nice RRS day |
